wifi and bt don't work
This is a discussion on wifi and bt don't work within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; After droping my nexus one wifi and bt don't work. Sending phone to the official repair shop is not the option at the moment. I ...
Thread: wifi and bt don't work
    Junior Member nexusjedan's Avatar
    Apr 2011
    After droping my nexus one wifi and bt don't work. Sending phone to the official repair shop is not the option at the moment. I have tried restoring to factory settings but I have only deleted my app and games :-(.
    My question is there anything that I can do about wifi and bluetooth myself and if not than how could I install app and games without wifi?
    Junior Member FastLove's Avatar
    Did you reset by going to the bootloader - clear storage?
    Apr 2011
    Just did but nothing have changed :-( while switching on wifi I get message Wi-Fi error.
    I think it is mechanical issue (something disconnected or broken) is there a way of installing applications and games manually ?
    Of course, you don't need wifi to install apps. But, you do need wifi generally for browsing etc. No?
    to install apps you need to have .apk files of the apps. Just have them on your microsd card and then click to open them on your nexus one and install.
    To download and install apps from market you need either gprs / 3g or wifi
