Nexus one stuck at the X screen
This is a discussion on Nexus one stuck at the X screen within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Done that. Placed the PASSIMG.zip on the SD Card and to the boot loader. It reads the PASSIMG files and then again goes to the ...
Results 11 to 20 of 46
Thread: Nexus one stuck at the X screen
    Junior Member san1jayin's Avatar
    Done that. Placed the PASSIMG.zip on the SD Card and to the boot loader. It reads the PASSIMG files and then again goes to the same bootloader screen.
    Senior Member 40ftcobb's Avatar
    Open the file you downloaded on your comp and see if there's another file in there I know the same thing happened to me the passimg I needed was in the the folder I downloaded not the actual download its self
    It doesnot have that. May be I am using the wrong one. Do you know where I can find the correct file so that I give it another try.
    Give. Me about an hour ill be at home and ill post the link
    Thanks for your help!
    Ok this is the link were I got my passimg from,
    http://forum.xda-developers.com/showthread.php?t=772591
    I'm not sure but if I'm thinking about the right one you may have to unzip in to its on folder on the comp then rename,but i might be wrong its been a while since I did this lol
    Android Lurker iPeck's Avatar
    Laval, Qc
    Honestly i dont remember unzip the file to the coming of the folder. Think i just renamed the downloaded file passimg.zip but not sure, been a while too.
    *Danger-rat or gravufo can surely answer this one... ?
    Try opening it to see if there another passion file inside,if there is rename it just passimg and use that
    For RADIO_V2, IT SAYS FAIL-PU
    Rest all is OK. At the end it says Partition failed, Do you want to reboot, I clicked on Yes and it is back to the same state, stuck at X.
    There was no Passion file inside so I used the entire zip file by naming it as PASSIMG
google nexus 7 2013 stuck at x
google nexus 7 stuck on x screen
google nexus one stuck on x screen
google nexus stuck on x
my nexus one stays on the x screen
nexus 1 stuck on x screen
nexus 10 stuck at x screen
nexus 4 stuck at x
nexus 4 stuck at x screen
nexus 4 stuck on x
nexus 4 stuck on x screen
nexus 7 x screen stuck
nexus one stuck at x screen
