Nexus one stuck at the X screen
This is a discussion on Nexus one stuck at the X screen within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I'm not sure if its case sensitive or not but try not using caps,and you put it on the root of your card right not ...
Results 21 to 30 of 46
Thread: Nexus one stuck at the X screen
  1. #21
    Senior Member 40ftcobb's Avatar
    I'm not sure if its case sensitive or not but try not using caps,and you put it on the root of your card right not in any folders
  2. #22
    Junior Member san1jayin's Avatar
    It is recognising the way I have put it.
    I get the below screen:
    Parsing...[SD ZIP]
    [1] Boot - OK
    [2] Bootloader - OK
    [3] Radio_V2 - Fail-PU
    [4] Recovery - OK
    [5] SP_CUSTOM - OK
    [6] SPLASHH1 - OK
    [7] SYSTEM - OK
    [8] USERDATA - OK
    Partition updtate fail!
    Do you want to reboot device?
    What should be done next? Is it that it will not work for HBOOT -0.35.0017?
  3. #23
    Sounds like it's finding the file OK, but cannot update the radio for some reason...
    Taking a step back, have you tried doing a factory reset?
  4. #24
    Yes. did that earlier.
  5. #25
    Had a quick read through the thread, and didn't see it.
    I'm just looking for the Korean image, because you may have more luck with it... Back in a minute...
  6. #26
    Try this:
    http://students.ceid.upatras.gr/~mav...ase_signed.zip
    After downloading, if you see .zip on the end of the filename rename to PASSIMG.zip, if you don't see .zip on the end of the filename rename to PASSIMG...
    Same trick as before...
  7. #27
    Still getting the same Radio_V2 - Fail-PU.
  8. #28
    Ya this is beyond me,lol I don't know that much lol
  9. #29
    Hmmmmm - I think you may be out of luck. Typically when there's a radio problem, there's not much in the way of options.
    Is your bootloader unlocked?
  10. #30
    How do I check that?
google nexus 7 2013 stuck at x
google nexus 7 stuck on x screen
google nexus one stuck on x screen
google nexus stuck on x
my nexus one stays on the x screen
nexus 1 stuck on x screen
nexus 10 stuck at x screen
nexus 4 stuck at x
nexus 4 stuck at x screen
nexus 4 stuck on x
nexus 4 stuck on x screen
nexus 7 x screen stuck
nexus one stuck at x screen
