Nexus one stuck at the X screen
This is a discussion on Nexus one stuck at the X screen within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Following is what I have done: C:\android-sdk-windows\tools>fastboot flash recovery recovery-RA-passion-v2.2.1. img < waiting for device > sending 'recovery' (3366 KB)... OKAY [ 0.500s] writing 'recovery'... ...
Page 5 of 5 FirstFirst ... 345
Results 41 to 46 of 46
Thread: Nexus one stuck at the X screen
  1. #41
    Junior Member san1jayin's Avatar
    OKAY [ 0.500s]
    OKAY [ 1.234s]
    finished. total time: 1.734s
    C:\android-sdk-windows\tools>fastboot boot recovery-RA-passion-v2.2.1.img
    downloading 'boot.img'...
    OKAY [ 0.516s]
    booting...
    OKAY [ 0.062s]
    finished. total time: 0.578s
    After this I have a screen with X on iy and a Lock below it. What should I do next?
  2. #42
    Try and see if it will boot into recovery:
    fastboot boot recovery.img
  3. #43
    When I do that, I get the following:
    OKAY [ 0.516s]
    booting...
    OKAY [ 0.062s]
    After this the phone goes back to the X screen after vibrating 7 times.
  4. #44
    I'm thinking you may have hardware failure - not sure what your options are, other than send it in for repair?
  5. #45
    Junior Member J4wD's Avatar
    Feb 2013
    same problem
    hey guys,
    i have the same problem, only thing is, my power button stopped working a year ago...so is there any other way i can try to fix it? or should i start looking for another phone?
  6. #46
    Android Lurker Alanis's Avatar
    Jul 2013
    thanks to be sharing
google nexus 7 2013 stuck at x
google nexus 7 stuck on x screen
google nexus one stuck on x screen
google nexus stuck on x
my nexus one stays on the x screen
nexus 1 stuck on x screen
nexus 10 stuck at x screen
nexus 4 stuck at x
nexus 4 stuck at x screen
nexus 4 stuck on x
nexus 4 stuck on x screen
nexus 7 x screen stuck
nexus one stuck at x screen
