Nexus one stuck at the X screen
This is a discussion on Nexus one stuck at the X screen within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; The phone switched off while charging and got stuck at the X screen. Tried to remove the battery and restart multiple times but nothing changes. ...
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Thread: Nexus one stuck at the X screen
    Junior Member san1jayin's Avatar
    Unhappy Nexus one stuck at the X screen
    The phone switched off while charging and got stuck at the X screen. Tried to remove the battery and restart multiple times but nothing changes. Phone stuck at bootup screen. After switching the phone on. Nexus X apears and keep reappering, noting else happens. Cannot swich off the phone, unless battery is removed. Anyone know what is the problem? If anyone has resolved this issue, please provide feedback.
    Android Lurker iPeck's Avatar
    Laval, Qc
    It happened to me once. i had to passimg 2.2.
    Can you elaborate? What do you mean by that?
    Laval, Qc
    Can you boot into the bootloader ? (Hold vol down while powering) if yes you can surely reflash the 2.2 rom to restore your phone.
    Done that. Placed the PASSIMG.zip on the SD Card and to the boot loader. It reads the PASSIMG files and then again goes to the same bootloader screen. What should I do next?
    Laval, Qc
    If the simple passimg doesnt work, then search for the "gravufo's tutorial" to go with the sdk setup with your comp . sorry, beyong this point i can't be of more help
    This happened to me once, I had to boot the phone into safe mode and then do a system wipe. That fixed it.
    Senior Member 40ftcobb's Avatar
    Ipeck has it,that's the easiest way its happened to me a couple times trying different roms.
    Did you name it just passimg (no. Zip)?
    yes. Named is just PASSIMG. Also it doesnot give me an option of booying in safe mode.
    Power off
    Hold down and power
    You should boot into hboot or fastboot can't remember but let your SD card load and it should give you an option to load update
google nexus 7 2013 stuck at x
google nexus 7 stuck on x screen
google nexus one stuck on x screen
google nexus stuck on x
my nexus one stays on the x screen
nexus 1 stuck on x screen
nexus 10 stuck at x screen
nexus 4 stuck at x
nexus 4 stuck at x screen
nexus 4 stuck on x
nexus 4 stuck on x screen
nexus 7 x screen stuck
nexus one stuck at x screen
