Low Space / Memory even after a hard reset
This is a discussion on Low Space / Memory even after a hard reset within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hi I recently acquired a Nexus One that I'm having memory issues with. I'm running Gingerbread 2.3.4 (GRJ22). I've tried all sorts of options in ...
Results 1 to 10 of 20
Thread: Low Space / Memory even after a hard reset
    Junior Member daftsynth's Avatar
    Hi I recently acquired a Nexus One that I'm having memory issues with. I'm running Gingerbread 2.3.4 (GRJ22). I've tried all sorts of options in erasing / clearing memory. After each of these attempts, it always only shows 13MB free. No extra applications are even installed! I've done the following: * Factory Data Reset * Clear Storage during HBOOT * Wipe data/factory reset during RECOVERY * Wipe cache partition during RECOVERY Any other ideas? I've recently rooted it too.
    Senior Member Luq07's Avatar
    What ROM are you using?
    the stock OTA Gingerbread 2.3.4 (GRJ22)
    bassmadrigal on xda suggested checking the /data partition for bad blocks - have you tried yet, I didn't see a response on xda?
    I can't seem to install terminal thru the marketplace. I think the low memory is preventing any additional application installs. Is that possible? Is there another method to access a shell prompt on the device?
    You can push the app to phone thru adb--I don't know command line though--better at Terminal
    You need to get your apps to sd thru the stock method or wipe all and flash Cyanogen CM7 followed by gapps and Dark Tremor.
    May need to read up on that if you haven't flashed a rom before
    People here or on those threads can help, depending on what you want to do
    [SIGPIC][/SIGPIC]
    San Francisco Giants
    I wouldn't even consider switching ROM until you know that your internal memory is stable...
    I'm thinking you'll have to hook your phone up to a PC, and take a look at the partitions. Windows won't be able to see the internal partitions, so you will probably need to go with Linux. If you don't already have a Linux machine, you can run Linux from a live CD or USB stick...
    running df, I get this: /data 196M 188M 7M 4096 I can't seem to run "df -h". I get this error: -h: No such file or directory
    The numbers are total size, used, available...
    It looks like you are using a lot of your data partition, or at least your phone thinks you are...
    Are you rooted, our is this a stock phone?
    I believe so. I am rooted. The ROM is Gingerbread 2.3.4. I just wiped out all data, cache, and reset the phone. This is what df displays
    # df
    df
    Filesystem Size Used Free Blksize
    /dev 192M 32K 192M 4096
    /mnt/asec 192M 0K 192M 4096
    /mnt/obb 192M 0K 192M 4096
    /system 145M 128M 16M 4096
    /data 196M 183M 12M 4096
    /cache 95M 2M 92M 4096
    /mnt/sdcard 1G 536K 1G 4096
    /mnt/secure/asec 1G 536K 1G 4096
    How do I clear it out?
did a hard reset and still low on spaces
even after reset phone still says low on space
factory reset android internal storage low
factory reset phone still low on space
i reset phone to factory settings and still low on space
internal memory reduce after factory reset
internal storage running low even hard reset
low internal memory android after reset
low memory after factory reset android
nexus 4 memory low after rom
nexus one memory low
still low on memory after factory data reset
surface 2 memory went lower after doing a reset
touchmate etab dou memory low after doing hard reset
why after reset phn memory phn space is reduced
