Power Button
This is a discussion on Power Button within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; My phone died, and the power button app doesnt turn on an off phone. I did however use the 'plug it in' and 'remove/install' battery ...
Results 11 to 13 of 13
Thread: Power Button
    Junior Member justanotherguy's Avatar
    I did however use the 'plug it in' and 'remove/install' battery trick to get it to wake up.
    After that, the app didnt work. I had to plug it in the car, the lock screen appears. Unlock, disable the 'fix button' app, and then re-enable it.
    After that I am back in busy-ness!
    Junior Member timss's Avatar
    Quote Originally Posted by justanotherguy View Post
    My Nexus One on/off button just failed. I tried "fix broken power button" and it doesn't work. Any other app to use the volume control to turn on the screen? Phone is not rooted.
    Timss
    Junior Member Ajay_nexusone's Avatar
    Feb 2013
    There's an app called "any unlock"
android advanced power button
android broken power button
android forum galaxy s3 power button
bugged power button
cost to fix phone power button htc sensation
extra power button on dashboard android
fix broken power button android died
galaxy s4 power button not always puts to sleep
how to fix htc sensation power button
my power button on my android died
nexus 7 power button bug
nexus one reassign power button
nexus phone power button short press
power button android phone issue
