Power Button
This is a discussion on Power Button within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Im thinking of getting an HTC Sensation but wonder if it will have the same power button issue as the N1 , They look to ...
Results 1 to 10 of 13
Thread: Power Button
    Android Lurker Michael A's Avatar
    Power Button
    Im thinking of getting an HTC Sensation but wonder if it will have the same power button issue as the N1 , They look to both be built the same . Is the power button issue specific to just the N1 or all HTC phones ?
    Until they made the nexus one they didn't have that problem but I would think they learned there lesson and are making them a little different now but I don't know for sure.
    Thank You Dude
    There is a website that takes apart phones and shows you what they look like inside. The problem with the N1 is the ribbon that connects to the power button is short and has a 90 bend very close to the power button. As a result it tears.
    I'd look up that website and see if they've done a tear down of the phone. If so watch the video and compare it to the video of the N1.
    Btw. If can be found on YouTube.
    That is what happened on both my N1's that ribbon has a tear half way across it. Now Im on some old junk phone I had in the draw , I will look at the tear down of the new phone Im looking at.
    Junior Member justanotherguy's Avatar
    Nothing can be done then? I cant put the phone to sleep, or bring it out of sleep to the 'unlock' screen. I shudder to think what would happen if the phone was shut off..... I can answer calls when the screen lights up and I slide to unlock, then I am in my phone like normal....
    No parts are available?
    Tony
    If you root you can assign other buttons to perform the same task as the power button...
    Worked great, I used an app called 'fix my broken power button'!!!
    Android Lurker iPeck's Avatar
    Laval, Qc
    I now use fix broken power button and works great. My power button is fine but for prevention.
android advanced power button
android broken power button
android forum galaxy s3 power button
bugged power button
cost to fix phone power button htc sensation
extra power button on dashboard android
fix broken power button android died
galaxy s4 power button not always puts to sleep
how to fix htc sensation power button
my power button on my android died
nexus 7 power button bug
nexus one reassign power button
nexus phone power button short press
power button android phone issue
