N1 CM7 Wifi issue!!!
This is a discussion on N1 CM7 Wifi issue!!! within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I flashed CM7 yesterday and it's GREAT. But when I try to connect to an adhoc wifi with my laptop my N1 keeps trying to ...
Thread: N1 CM7 Wifi issue!!!
    Junior Member Fido86's Avatar
    Jun 2011
    I flashed CM7 yesterday and it's GREAT. But when I try to connect to an adhoc wifi with my laptop my N1 keeps trying to obtain an IP but it couldn't.
    I'm using windows Xp SP3 on my laptop. Any known solution for this issue??
    H.E.L.P
    Metro Atlanta
    53 times
    The ability to connect to an ad-hoc network is not supported on the Nexus One. I'm not sure about other Android devices, though. Actually, you should get a popup window that says just that.
    Jun 2011
    Is there any alternative way to share the internet connection with N1. I mean LAN internet connection?
nexus one wifi problem cm7
