Sound only works with headsets
This is a discussion on Sound only works with headsets within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hello, I am using Nexus one and 2 days ago my sound all went off except when I plug my headsets. When I unplug my ...
Thread: Sound only works with headsets
    Junior Member enzoo14's Avatar
    Jun 2011
    Hello,
    I am using Nexus one and 2 days ago my sound all went off except when I plug my headsets. When I unplug my headsets, all phone sounds disappear although I made sure all sound is enabled and is at max.
    The only time I had sound again without the headsets is when my brother called me yesterday, the ringtone did not work immediately but a few seconds sound came back for about 3 seconds then went away. I have tried resetting the phone back to factory settings following this guide How to hard reset the Google Nexus One - Know Your Cell
    but the problem still persists I only get sound, from ringtones pressing buttons and so on only with any headsets plugged in.
    I would be very grateful if someone is kind enough to help with this issue as it is very irritating.
    Thank you very much!
    Sounds like a hardware issue - possible a loose connection to the rear speaker...?
    Jun 2011
    So the only way to fix it is to go back to my phone provider?
    I'm only guessing, but that's what it sounds like. If the phone is in warranty than send it to HTC, if not, then take it to a local repair shop or do it yourself...
    Jun 2011
    Thanks alot your the best, I removed the back cover and just pressed firmly on the rear speaker and sound just went back on. ^_^
    How many software engineers does it take to replace a lightbulb?
    None, it's a hardware problem :rofl3:
  1. why wont my phone connect to my computer
    Last Post: 10-14-2010, 09:04 PM
how to fix hardware problems with android headset sound speaker issues
kindle fire sound problem -no sound when unplug speakers
my sound will only work on my phone with headset
nexus only work on speaker
sound on my kindle fire only works with headset
