changing custom roms=network errors!
This is a discussion on changing custom roms=network errors! within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; hello there, i rooted my phone ,it was on stock 2.2 and flashed a cyanogen nightly#98 and the g.apps as well.it was perfect. suddenly i ...
Thread: changing custom roms=network errors!
    Junior Member demertis's Avatar
    hello there,
    suddenly i decide to flash the newest nightly and the g.apps as well.
    since then the network gives me error.!!!!!!
    every time i switch to the stock rom 2.2. everything is ok.
    1.before flash custom rom i do a wipe/factory reset and wipe cache partition.
    is there any chance that changing beetween roms effecting the network?
    some junk remaining on the phone that interfear with the os?
    please some suggestions?
    i will to the same to the newest nightly today #105 and see if it is better!
    some help
    how will i clear the phone from junk previous installation ROMS???soo the new custom rom will be clear?
    Senior Member 40ftcobb's Avatar
    Did you check your apns?
    I know with certain roms I lose my apns and have to re-enter them.
    As for cleaning when you flash do you use rom manager?
    http://forum.xda-developers.com/show...3844&page=1767
    As for cleaning,I use this, flash it like you would a rom,then wipe all 3,at least.
    thanks
    no i have not interfeared with APNs.Is it necessary since i connect from my wireless wifi at home.my wireless is ok because i am on the net right now from my laptop,so something has gone wrong with settings of nexus one.
