call barring settings
This is a discussion on call barring settings within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hi I'm having problems with the call barring settings. Ummm...where do disable it? Please help me....
Thread: call barring settings
    Junior Member dorkyretardify's Avatar
    Uh... could you give a little more details cause I'm not exactly sure what you mean.
    Ok...i am currently using globe telecoms' roaming services (philiwthppines) when i try to call to load my sim. It's saying that my phone doesn't allow outgoing calls because call barring is on..wth?!
    Looks like it's carrier specific. You need to contact the provider to get the codes to use.
    GSM Feature Codes
call barring galaxy ace
call barring is not allowing me to.make calls galaxy ace 4
call barring nexus 4
call barring password samsung galaxy grand
call barring samsung grand
call barring settings android
how to activate call barring in samsung galaxy ace
how to deactivate call barring on samsung
how to turn off call barring off samsung ace
how to turn off call barring on android 4.1.2
how to turn off call barring on samsung galaxy grand
no call barring on samsung galaxy ace
outgoing intl roaming barring android
samsung galaxy grand call barring password
