No sound through earpiece
This is a discussion on No sound through earpiece within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hi, I recently bought the Nexus One. After a couple of days i tried to manually update it to Gingerbread but the update failed. Post ...
Thread: No sound through earpiece
    Junior Member jghadiali's Avatar
    Jun 2011
    Hi,
    I recently bought the Nexus One. After a couple of days i tried to manually update it to Gingerbread but the update failed. Post that, whenever I make or receive a call, I cannot hear the other person via earpiece. But if I plug in the headset or put the call on speaker, I am able to hear the other person.
    Could the failed update have damaged the earpiece?
    Kindly help.
    Android version - 2.2
    Baseband version - 32.41.00.32U_5.08.00.04
    Kernel version - 2.6.32.9-27227-g3c98b0d haley@m4-dev #1
    Build number - 2.16.405.1 CL223106 release-keys
    Well did it work before you tried the update? If no then it's probably hardware but if yes then that is strange because I have seen people that failed to update for the same reason as you and there ear piece still worked.
    BTW if your wondering why you can't update it's cause your on a carrier modded ROM to get back to stock and receive the update just follow the restore guide in this thread. http://www.nexusoneforum.net/forum/n...t=nexus+oracle
    Jun 2011
    Yes. It did.
    Ok well in that case I would follow the restore guide I sent you in my last post.
    Jun 2011
    Thanks Dude.. Will do that and revert.
    Jun 2011
    I got the earpiece replaced by the vendor. Post that the sound is mettalic and audible only in quiet surrounding. On road or in noisy place the sound is not at all audible. I have escalated this to my vendor.
    Any suggestions why is this happening?
android ginggerbread galaxy s earpiece not workin
android no sound from earpiece
earpiece droid quiet
google nexus one no sound.
nexus one earpiece not working
no sound from earpiece android
no sound from earpiece on samsung galaxy 4 phone release
samsung galaxy nexus no sound from earpiece
samsung galaxy s earpiece not working
