Autosuggest problem after update to 2.3.4
This is a discussion on Autosuggest problem after update to 2.3.4 within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Thanks Danger-Rat, but unfortunatly no succes. It seems that the dictionnary just vanish. I'll make some researchs and if I find something I'll post it ...
Results 11 to 12 of 12
Thread: Autosuggest problem after update to 2.3.4
    Junior Member Jeff15's Avatar
    It seems that the dictionnary just vanish. I'll make some researchs and if I find something I'll post it here.
    Until then I am using Better Keyboard with the french dic.
    Junior Member yoozer's Avatar
    Quote Originally Posted by angxela View Post
    I had this problem and it drove me nuts. Here's how I fixed it.
    After mucking about in the Settings, making sure the correct language was selected everywhere possible, yet getting nowhere, I went on the Android market and downloaded a new keyboard (Keyboard from Android 2.3 by Steven Lin). It was free.
    The problem persisted, even though the keyboard was selected in Settings -> Language & keyboard -> (Gingerbread keyboard was checked).
    Then I went to Settings -> Language & keyboard -> Gingerbread keyboard settings -> Input languages -> (make sure that the correct language is checked).
    It also doesn't hurt to check that Settings -> Language & keyboard -> Gingerbread keyboard settings -> (Show suggestions should be checked).
    The problem PERSISTED, and I was running low on patience. Then I found this hint on the app's store page:
    You have to go to any text field, such as messaging or email. Tap it once to bring up the keyboard. THEN PRESS AND HOLD on the text field until a little menu comes up, and select Input method, then select Gingerbread keyboard from the options.
    Problem fixed! ::happydance::
    THANK YOU THANK YOU THANK YOU
    I have been struggling for a couple of weeks with this issue!!
    All fixed
android 2.3.4 autocorrect
android 4.3 update trouble shooting
android capitalization problem
android input method auto suggest
auto correct android 2.3.4
autosuggest issues on tablet
grom and2 doesn't work with android 4.3
