After 1.5 yrs, N1's power button no longer works
This is a discussion on After 1.5 yrs, N1's power button no longer works within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hello, My issue is very simple. I press the power button to turn on/off/lock the phone. Now it does not work/respond. It will only response ...
Thread: After 1.5 yrs, N1's power button no longer works
    Junior Member darbebo's Avatar
    Hello,
    My issue is very simple. I press the power button to turn on/off/lock the phone. Now it does not work/respond. It will only response if one of the following happens:
    1. I plug it in a USB/Charging station (assuming the phone is still on)
    2. I get a call (assuming the phone is still on)
    So basically if there is a situation where I need to turn OFF the phone, I have to literally pull out the battery. If i have to turn the phone back on , I have no way to do it. That's why I haven't done that yet.....but imagine if if it dies when the battery runs out or when it froze and I have to force restart....
    A reference to the issue:
    Manage a Nexus One with Broken Power Button [Updated] AndroidGuys
    So now that froyo has been released and many updates after. I don't know if the "rooting" method / trackball wake is still usable and I am interested to know if there's anything I can do to fix this without sending it to HTC for a fee or something
    Note: I haven't rooted my phone at all. Normal phone user only.
    One place claims they can fix it for approx $100 including parts and labor. But I don't know if i want to do that yet.. I have 1 yr till the contract ends..... gaah
    please advise
    Android Lurker iPeck's Avatar
    Laval, Qc
    I use fix power button app wich has a widget to turn off the screen and you can wake the phone with volume button. (Cm7 rom can let you use the volume and trackball to wake too).
    To turn on your phone when its off, plug the usb cord, wait for you to see that its charging, then remove the battery and put it back. The phone will now boot.
    Junior Member einc70's Avatar
    Jun 2011
    If I only have a regular wall charger, will it work in place of the USB charger to "wake the phone up" after it is off?
    Laval, Qc
    Hmm not sure
    Try it....
    Yes it works on mine.
app to switch on my nexus one without the power button
how do you force a phone to turn on googles nexus when the power button doesnt work
how to fix google nexus one power button
how to turn on phone if power button no longer works
manage nexus one broken power button
n1 fix power button
nexus one does not turn on
nexus one power button fix
nexus one start without power button
nexus s 4 will not turn on
nexus s on/off button no responsive
orsngr light
