"adb devices" works but "adb connect" fails (Nexus 1, both winXP 32bits and Ubuntu)
This is a discussion on "adb devices" works but "adb connect" fails (Nexus 1, both winXP 32bits and Ubuntu) within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hi all, First post (Maiden voyage?). Welcome to myself :-) I have received a Nexus 1 phone as my development testbed, but I am somewhat ...
Thread: "adb devices" works but "adb connect" fails (Nexus 1, both winXP 32bits and Ubuntu)
    Junior Member ronubo's Avatar
    Hi all,
    I have received a Nexus 1 phone as my development testbed, but I am somewhat stuck in getting started since I can't connect to it.
    On the phone itself, which has the Gingerbread 2.3.3 version, I have "USB Debugging" on.
    I see the following behavior on both Windows XP 32bits, and Ubuntu 11.04 64 bits:
    Code:
    C:\Program Files\Android\android-sdk\platform-tools>adb devices
    List of devices attached
    0123456789ABCDEF        device
    C:\Program Files\Android\android-sdk\platform-tools>adb connect 0123456789ABCDEF
    unable to connect to 0123456789ABCDEF:5555
    I am pretty sure that the USB configuration is OK in both operating systems, and I have not met on my web searches a scenario where "adb devices" would work whereas "adb connect" fails.
    Does anyone have an idea of how to overcome this issue?
    Thanks,
    Ron.
    Something more:
    Doing activities with "adb -d" seems to work - if it is the ONLY device connected.
    But if I have multiple devices connected (which I do), it is impossible to select one, unless connecting to it via TCP. ("adb connect x.y.z.w").
    This was not the behavior when I tried to connect to a XOOM tablet I own, or at least it wasn't in Linux. (It's my first attempt at Windows)
    Any clue?
    Thanks,
    Ron
    Unfortunately, I've never had to connect to multiple devices so I've never experienced this. When I get time I'll have a play though, and let you know what I find (may not be in the immediate future)...
    Thanks.
    So the way you use adb is always with "-d" ?
    Nope, just "adb <command>" plus any switches, etc...
0123456789abcdef
adb 0123456789abcdef
adb connect unable connect
adb device 0123456789abcdef
adb devices 0123456789abcdef
adb unable to connect for backup
adb unable to connect for backup nexus 4
adb unable to connect to 5555
adb: unable to connect for backup
found device...0123456789abcdef
nexus 4 adb: unable to connect for backup
ubuntu unable to connect adb connect
unable to connect for backup nexus 5
unable to connect to 0123456789abcdef
www.android.net 108697-adb-devices-works-but-adb-connect-fails-nexus-1-both-winxp-32bits-ubuntu
