Battery draining
This is a discussion on Battery draining within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; For the past two nights my battery has completely drained of life overnight. It was fully charged before and just idle. On checking the battery ...
Results 1 to 8 of 8
Thread: Battery draining
    Junior Member princecoco's Avatar
    Battery draining
    For the past two nights my battery has completely drained of life overnight. It was fully charged before and just idle. On checking the battery usage is says Android OS 72%! Surely that is way too high. It's using Android version 2.3.4. Any ideas why or should I just get a new battery?
    thanks
    Junior Member adithyat149's Avatar
    Jun 2011
    Use Battery Dr to monitor the battery usage. Might be you switched ON GPRS, GPS, WIFI...!!!
    Nope, none of these things are running!
    Jun 2011
    Alarm? Sometimes I faced the problem of Battery Draining also due to this.
    No alarm. I have nothing running other than syncing to my gmail and facebook accounts.
    Jun 2011
    Yaa Syncing also causes little bit of battery. Try 1 night without syncing. And also provide what other features are running. (Go to Menu [second button from left on bottom]>Manage Apps>Running)
    Thanks. Apps running are:
    Settings
    Lookout
    Android System
    Googel SErvices
    market
    maps
    Android keyboard
    Jun 2011
    Close Market (May be background Data is ON. Go to Settins>Accounts & Syc. Make it OFF), maps, Android System and Google Services. Also while in Running Apps, press menu again to go to cached apps and close all.
108777 battery
android device idle battery drain
android os battery drains sometimes
android os draining battery galaxy s3
android os draining battery galaxy s4
android os draining battery in galaxy s4 active
android os draining galaxy s4 battery
android sometimes has incredible battery drain
battery draining nexus 10
galaxy s3 system idle draining battery overnight
nexus 7 battery drain in idle
nexus 7 battery drain when tablet idle
problems with battery draining on galaxy s4
s4 battery draining android os
tablet battery draining
