Nexus one problem
This is a discussion on Nexus one problem within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; i have stuck with :nexusx: and lock in bottom of screen...
Thread: Nexus one problem
    Junior Member almagid2004's Avatar
    Nexus one problem
    Metro Atlanta
    53 times
    Can you tell us what you were doing when this happened? Did the phone work properly before? I think we'll need more information in order to help you here.
    thank you for replay
    the phone was working fine but i was trying to install arabic langauge so i follow this intrction http://www.nexusoneforum.net/forum/n...nexus-one.html and than i get stuck on the third step
    Ok this should be relatively simple just follow these instructions and it will bring you to the original ROM then I'll provide you with some more help to get you on to the Arabic language ROM.
    http://www.nexusoneforum.net/forum/n...html#post98568
    i need help
    i did try again and than when i am on this step 2.5-Go back to the cmd window, and type: "fastboot-windows flash recovery recovery-RA-nexus-v1.5.3.img" then Enter
    3.1: From that white background screen choose: "BootLoader"
    3.2: Then choose: "Recovery"
    i did not see any menu i get only black screen
    Try a version of Amon Ra that is 1.8 or higher. The old versions don't support the newer SLCD screens...
    thank you the step that you tell me work
    but the update_ar2_n1_corrSkia.zip i can not downlaod it the link is not workin can you give me another linke
    than you
corrskia.zip
nexus one stuck on android screen
