screen not showing anything
This is a discussion on screen not showing anything within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; so i had to take apart my phone to replace the charger jack. after i put it back together the phone turns on and all ...
Thread: screen not showing anything
    Junior Member locorito's Avatar
    Sep 2011
    so i had to take apart my phone to replace the charger jack. after i put it back together the phone turns on and all of the buttons work but the screen is blank. even the digitizer works as i can unlock the phone lock it and push the home menu search keys on the front. dunno if maybe i put something together wrong, anyone know where the screen gets its power from so i can check and see if maybe i put something back wrong.
    I personally don't but you could check ifix it they have a tear down so you could check that out.
my phone works but the screen is not showing anything
nexus 7 will not show anything on the screen
