Complicated Boot Issue.
This is a discussion on Complicated Boot Issue. within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; So, a customer gave me their nexus one today. He didn't know how to get it fixed so he let me have it. There are ...
Thread: Complicated Boot Issue.
    Junior Member bugmenever's Avatar
    So, a customer gave me their nexus one today. He didn't know how to get it fixed so he let me have it. There are a couple of issues with the phone.
    1. The top power on button is not even there anymore.
    --->I got the phone to power on while having it plugged in and pulling battery and re-inserting it.
    2. It boots to the "X" screen but doesn't go anywhere.
    --->I can get into recovery.
    3. When i get into recovery to do a master reset i am not able to press the power button because there isn't any button, and when i press the button that's still inside there is no response, the trackball does no good either -__-.
    I'm thinking if i somehow am able to flash a .nbh file from the sdcard i can somehow master reset the phone that way.
    --->If i can't find any options i'm thinking of buying a top power button and dissecting the phone to try and install a new button.
    What do you all think? Any response would be greatly appreciated. Thanks!!
    I would try the passimg method to see if that fixes it if that doesn't I wouldn't even bother trying to replace the power button because it has another hardware problem two so I would send it in to htc and get it fixed.
    Instructions for passimg method http://www.nexusoneforum.net/forum/n...html#post98568
