HELP!!! Nexus one frozen at boot-up.....vibrates 7 times. WTF!!!!
This is a discussion on HELP!!! Nexus one frozen at boot-up.....vibrates 7 times. WTF!!!! within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I was at work today and i look at my phone and the screen is showing the boot up X nothing was happening so i ...
Thread: HELP!!! Nexus one frozen at boot-up.....vibrates 7 times. WTF!!!!
    Member Rocco D'Voe's Avatar
    nothing was happening so i pulled the battery and it did the boot up screen then vibrates 7 times.
    tried leaving the battery out, same thing.
    tried doing the vol down/power thing and none of the functions, bootloader, recovery, or anything else are doing squat.
    my phone was never rooted and it automatically updated to 2.3.6 just a few days ago.
    what the hell is going on and can someone please help!?
    If you haven't tried it yet, try booting it into safe mode and then see if it boots up. If it does, great, then try restarting it in normal mode.
    If that doesn't work, I would suggest booting into safe mode again and erasing it and starting over from new out of the box.
    If the Nexus One is freezing or won’t start properly, you may want to try to start it in Safe Mode. Safe Mode will allow you to start the smartphone with the default software running so you have a chance to disable any software you’ve installed that may be causing the problem.
    Perform these steps:
    1. Power the device off. Take the battery out if it won’t turn off normally.
    2. Power the device on.
    3. When the logo appears, press and hold the the track ball.
    4. Continue holding the Menu button until you see the home screen.
    The words Safe Mode should appear in the lower left corner if you performed the steps correctly.
    i tried holding the trackball during startup but nothing happens, it just stays on the X logo.
    Sorry, that is all I can suggest. Maybe someone else will chime in with suggestions. Best of luck.
    If I recall correctly, seven vibrations indicates a hardware problem... :/
google nexus one vibrates 7 times
how to unfreeze a tablet
htc bootup 7 vibrates
nexus 10 frozen on start up
nexus 7 2 freezes on boot
nexus 7 freeze on start up
nexus 7 freezing at start up
nexus one 7times
nexus one freeze at x logo
nexus one froze, vibrates 7 times
nexus one power on vibrates 7 time
nexus one power vibrates 7 times
nexus one won't boot vibrates seven times
nexusone vibraes 7 times when booting
