Picture Message Problem
This is a discussion on Picture Message Problem within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; It seems that as of late every picture message i receive looks blurry....i dont know what happened all of a sudden. Any ideas or suggestions? ...
Thread: Picture Message Problem
    It seems that as of late every picture message i receive looks blurry....i dont know what happened all of a sudden. Any ideas or suggestions? Im on cm 7.0.3
    Go into the settings in your messaging app and change the custom user agent. You may have to experiment, but I believe the Nokia UA works quite well...
    ok will try that, hopefully it works. why would it mess up all of a sudden tho, i havent messed with those settings
