Phone wont work with SIM card
This is a discussion on Phone wont work with SIM card within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I bought a Nexus One from some dude on craigslist and it is unlocked. The phone works fine without a simcard in it but whenever ...
Thread: Phone wont work with SIM card
    Junior Member rmannn94's Avatar
    Nov 2011
    I bought a Nexus One from some dude on craigslist and it is unlocked. The phone works fine without a simcard in it but whenever i put my sim card in it, it would run for a short period of time and it will then go to a screen with a colorful "x" and an unlock icon and it wont get out of it. Im new to all this unlocking stuff and i just wanna know how can i get my phone to work properly with my SIM card?
    Senior Member Luq07's Avatar
    You are getting stuck on the boot screen. That sounds like a hardware issue. Did you try it with a sim card before you bought it? I had an issue similar to this when I got my phone wet. Wifi worked fine, apps and everything else worked but no sim cards would work. It would either reboot and stay on the boot screen or it would refuse to connect to the phone network. I finally got the thing to stop rebooting but the phone network portion was completely dead. I ended up sending it in to HTC for repair. Cost about $170 to replace the motherboard. I suspect you were conned. Return it and get your money back. If you can't, you basically have an nice ipod unless you spend the $$ to get it fixed. Sorry.
android internet wont work without sim card
android phone wont unlock sim
got phone wet and network wont work#gsc.tab
my phone wont work on *#06#
my sim card wont work in my galaxy s4 intl version
my sim card wont work in my nexus s
nexus 4 sim card wont connect to network
nexus s wont read sim
nexus s wont read sim card
sim card wont connect on unlocked phon
sim card wont work in galaxy s4
sim card wont work on android
sim card wont work on galaxy s4
sim wont work in nexus
youtube android wont work without sim card
