After a couple months of successful hacking, today, the screen stops working. I'm on blandroid 2.3.7 ROM, and I've been running it just fine without any problems. I clicked the power button today, and the screen doesn't wake. I boot without the SD card and SIM card, still doesn't work. Did a factory reset on my phone, still doesn't work. Flashed a nandroid backup from a month ago, still doesn't work. The only way I can view my phone is connect to PC, and use Android-sdk to navigate with screenshot viewing enabled. At this point, I'm sure it's a hardware problem (ex. screen disconnected from a cable inside, etc.) How would I go about handling this? My bootloader is unlocked, and I ran out of warranty, so I'm not sure if I should send it to HTC. Is it just time to upgrade to a new phone?
-All help welcome,
Alex
