USB / charger connector "loose"
This is a discussion on USB / charger connector "loose" within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; My USB / charger connector seems to disconnect from the computer connection sporadically. I assume this means I need to replace either the internal connector ...
Thread: USB / charger connector "loose"
    Junior Member edwardarroyo's Avatar
    My USB / charger connector seems to disconnect from the computer connection sporadically. I assume this means I need to replace either the internal connector itself, or the whole Mother Logic Board it is connected to. Anyone else have this problem and a solution?
    Senior Member Luq07's Avatar
    I have the same problem. I tried using the dock but now even that isn't working. I think its a motherboard replacement type of situation. Looks like I'll finally be giving up my nexus one.
    According to ifixit.com, You need the motherboard replaced. Here is the part:
    HTC Google Nexus One Motherboard Logic Board Replacement
    Thanks. I'm already replacing the upper flex cable ribbon assembly, so when I go in there I'll inspect the USB connection to the mother board and see if I can solder or otherwise tighten the connection.
android tablet loose connection usb
google nexus charging port loose
loose port nexus 5
my google nexus loose charging connection
nexus 7 battery not charging - cable connection seems loose
nexus 7 charger port loose
nexus 7 i/o assembly cable
nexus 7 loose battery connector
nexus 7 loose charger
nexus 7 motherboard replacement will i lose my pictures
nexus 7 usb port loose
nexus tablet charger port is loose
samsung android charging problems loose connection
tablet battery connecter is loose
usb power charger charging connector port flex cable for asus google nexus 7
