nexus one not booting up
This is a discussion on nexus one not booting up within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; hi, My nexus one wont boot up . when I power it on, the X loops for 9 times and then freezes, again for 9 ...
Results 1 to 8 of 8
Thread: nexus one not booting up
    Junior Member jayguru11's Avatar
    hi,
    My nexus one wont boot up . when I power it on, the X loops for 9 times and then freezes, again for 9 times and freezes, keeps going on... I cant even power it off, without removing the battery. i tried powering it on without the sim. but still no use. What do i do now ?
    i don't know if i can help
    but we would need more info like
    are you rooted and if so what recovery
    install any new apps
    what were you doing right before this happened
    what methods have you tried to pwr on
    [SIGPIC][/SIGPIC]
    San Francisco Giants
    i just tried to power it on using the power on button. I didnt install any new apps. I was browsing, the browser got force closed, all the other apps would also get force closed. So, I did power off, it has not booted up since. I dont know what u mean by rooted? pls explain...
    thank you for replying .
    if you are not familiar with root term, then you are not rooted. it gives you admin access to your system files and allows you to install custom recoveries and roms. and helps to be able to get out jams like this.
    do you think you picked up a virus from browsing
    can you hold down pwr button and trackball at same time and boot into fastboot screen with the 3 androids at bottom
    [SIGPIC][/SIGPIC]
    yes i did
    i got the 3 android screen.. now what do i do?
    what did you think about a virus
    you can try to reboot from there and see if it works--just hit vol- to highlight reboot
    after that you can get back to that screen and try clearing storage--not sure what you will lose as far as your data goes--you may have to lose it anyway to get fixed
    you could take your sdcard out and try to pwr on but also back it up with a card reader to pc
    before doing storage clear, maybe give some time for other ideas here
    [SIGPIC][/SIGPIC]
    I had lookout antivirus installed, so i thought , it might not be a virus.
    i didnt have much data in the phone, so i did the clear storage option. it worked, thanx a lot for your help )))
    very happy i was able to help
    the antivirus program may even be your problem--not sure
    if you are careful--may not need one
    [SIGPIC][/SIGPIC]
google nexus one hangs on boot
htc google nexus one not booting
htc google nexus one wil not turn on past x
htc nexus one not booting
htc nexus one troubleshooting
htc nexus one wont boot
htc nexus one wont boot up
my++htc+google+nexus+one+phone+did+not+start up
nexus one freeze on boot
nexus one freezes on boot
nexus one will not boot up
problem google nexus one not booting
why do my htc nexus hangs on starting
why dont my nexus one start up
