Phone "crashes" after phone call
This is a discussion on Phone "crashes" after phone call within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hey there, I just bought an old Nexus 1 off my buddy, and I'm having an issue with calls. Often when I make calls (outgoing ...
Thread: Phone "crashes" after phone call
    Junior Member yoelbenyossef's Avatar
    Jun 2012
    Hey there,
    Often when I make calls (outgoing or incoming), after the call, the screen won't come back on. The only way I have of fixing this is to take the battery out and putting it back in.
    I have found however, when I plug it in, the screen will come back.
    The phone was rooted by my buddy.
    And, everything else works well, except the camera which does not work.
    Has anyone else seen this issue, or have any idea how I can fix/debug it?
    Thanks,
    Eric
    Junior Member cinders's Avatar
    Jun 2012
    I'm not an expert but is anything covering the proximity detector (far left of the ear piece) like a case etc, this would cause the screen to stay blank after a call.
    Junior Member gkparkinson's Avatar
    Jun 2012
    Same problem...
    I have been trying to solve exactly the same problems for a little over 3 weeks now. Problems started after passing through airport security (whether this is actually related I don't know). Now, camera fails on launch and phone becomes unresponsive on answer after trackball flash...
    The phone was stock, Froyo, when I got it. After problems started I rooted it and upgraded to 2.3.7 with CyanogenMod 7.2, but problems persist. I have done several factory resets and a hard reset with no change. There is no apparent obstruction of proximity.
    Diagnosis or solution greatly appreciated.
android crash after call
android crash after phone call
android phone call crash
android phone crash after call
android phone hangs after call
blackscreen freeze during calls cyanagen
cyanogen black after call
cyanogenmod 7 crash after call
cyanogenmod 7.2 nexus one turns off|crashes
cyanogenmod 7.2 screen after call
cyanogenmod call crash
freeze and black screen after call android
htc nexos one freezes calls
nexus one screen is unresponsive after phone call
