Blackrose Resize CWM help?
This is a discussion on Blackrose Resize CWM help? within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hey, I resized my Nexus One blackrose to ICS and I installed 4EXT Touch Recovery but when I used Blackrose to resize its gone? I ...
Thread: Blackrose Resize CWM help?
    Junior Member iTzTrevor's Avatar
    Jul 2012
    Hey, I resized my Nexus One blackrose to ICS and I installed 4EXT Touch Recovery but when I used Blackrose to resize its gone? I went to recovery on the bootloader and all that shows up the "!" inside a triangle next to the little android so as regular booting it up. I didn't know Blackrose also wipes out the recovery and I used some one click root just to get it.
    I've been reading in the forums about flashing CWM on the phone using Fastboot. But heres the thing. I dled fastboot.exe , the dll file and adb.exe and ran the cmd to install CWM but all it says is error cannot load "recovery.img(i renamed it)" Can someone send me a thread or link or anything that can teach me how to install CWM on it. I really don't know how to use Fastboot at all or Android SDK if it's needed. I checked the Wiki and it doesn't really say.
    yes blackrose can and has wiped recovery
    the one click root is the easy way but won't help you out of trouble like you are in
    best to root the old way by downloading the files you did or installing and using sdk which installs the files for you to a tools or platform-tools folder in the sdk folder. it took me many hours of googling to figure sdk/adb/fastboot out
    i don't have my n1 anymore and am ready to call it a nite--long work day tomorrow
    but if you get all those files into a folder on your C drive--call it fastboot if you want to, then you can see if fastboot and adb commands work--need n1 drivers installed too
    then you need to open a command window and cd (change directory) to your C: fastboot folder
    open command window
    cd/ <enter>
    cd fastbboot <enter>
    then after that and on same line type adb devices
    your phone must be plugged in with OS running and usb debugging must be checked in settings/dev options
    if you get your phone ID# after adb devices, then type adb reboot bootloader
    you should boot into fastboot, then type fastboot devices <enter>
    another #---- should come up
    you now need to make sure you have the correct recovery image in the fastboot folder--just the image
    if so, type fastboot flash recovery recovery.img where recovery.img is EXACT name of the image file. check that before hand by right clicking on image and then properties. at this point i usually just copy/paste the image name to the command line
    it should let you know if recovery flashed
    then fastboot reboot-bootloader
    if you boot to bootloader (red fastboot highlighted) you can navigate to recovery and install a rom that has SuperUser in it to get good root
    ideally if you can get the Super User zip and a rom on sd card prior to all this you can install the rom then the SU zip while in recovery
    either way you need at least a rom with SU in it on sd card, a nandroid with a similar rom on sdcard or you may have to push a rom to sdcard thru adb
    you can see why adb and fastboot knowledge are necessary--
    if you get to booting a rom do a nandroid backup right away and a good idea to backup sdcard to pc also
    i also found it better to use fastboot commands for blackrose and splhexeditor to change partitions
    haven't done this for awhile as i have been rooted for several years, so hope i didn't leave anything out
    maybe one of the mods/techy members can confirm or correct me
    also the xda n1 forum, where i guess you have been can help also
    good luck
    [SIGPIC][/SIGPIC]
    San Francisco Giants
    Junior Member c2med's Avatar
    Aug 2012
    Quote Originally Posted by iTzTrevor View Post
    You probably figured out how to fix your problem by now, but if you installed 4ext recovery, then it saved a recovery image that you can flash via fastboot while your phone is in recovery. It should have saved the recovery image on your SD card in SD/Download/4EXT_Recovery_Touch/ and be named "recovery.img". Unzip and copy the recovery.img to your computer. Then use fastboot to flash it to recovery. Instead of rehashing what is already out there check out these links:
    Nexus One: Full Update Guide - CyanogenMod Wiki - this will show you how to download and use fastboot and flash a recovery image.
    c2med Blog - Technology News, Reviews, and Tutorials: How to Install SpazeDog Jelly Bean or Ice Cream Sandwich on a Nexus One - this will show you how to update to ICS or JB using BlackRose.
    Hope this helps
blackrose bootloader not working
blackrose nexus one
blackrose not working nexus one
blackrose partition guide
fastboot resize
resize with black rose from windows
