This is probably something that was already discussed here, but I couldn't find anything closer to my problem.
I have a N1 that has the power button broken for a while. I've been dealing with it using the battery trick - very annoying but it actually works.
Few days ago, the phone now is stuck in the boot screen forever, and although I can enter the bootloader screen, I can't select anything since the OK function is performed by the power button.
I already tried drain the battery, remove SIM and SD card (guessing) and everything else. My next attempt would be using android sdk to force a reboot, etc... but with now power button that seems impossible.
To make things worse, the phone cannot be also detected by the computer (USB).
Is there any possible way to solve this problem!?
Thanks
Paulo
