Help! Serious Issue - pre-release nexus one dropped it's ROM
This is a discussion on Help! Serious Issue - pre-release nexus one dropped it's ROM within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I'm testing a nexus one a friend trusted with me, and after doing a privacy reset on it to remove his data, the phone will ...
Results 1 to 10 of 12
Thread: Help! Serious Issue - pre-release nexus one dropped it's ROM
    Junior Member nexus_one's Avatar
    Exclamation Help! Serious Issue - pre-release nexus one dropped it's ROM
    I'm testing a nexus one a friend trusted with me, and after doing a privacy reset on it to remove his data, the phone will not boot. It seems like the rom is missing. All the phone does is display three androids on skateboards.
    Can anyone provide me with the ROM for my phone?
    Thanks!
    Metro Atlanta
    53 times
    Unlikely at this point, as nobody has one in the wild yet. Maybe your buddy can help...IF you can face him. :D
    4Nines
    Guest 4Nines's Avatar
    Dang man I wished I could help, but I haven't been fortunate enough to even see one in person yet
    JimMariner
    Guest JimMariner's Avatar
    Sounds like someone needs to do some serious apologizing to his friend and beg for their help. Cause as ADMIN & Wera Said, Ain't none of them in the wild yet. And very little it known about what makes them tick, beep or ring.
    Keep us updated on how it all turns out for you !!!!
    Good Luck !
    4Nines
    I know you're probably scrambling around, but is there anyway that you can get us some pics of it and any info that we might not know?
    Maybe this would help us get some members that would be able to help you out
    Admin
    Guest Admin's Avatar
    Quote Originally Posted by nexus_one View Post
    Thanks!
    How about getting us some good high quality pictures of the phone as well
    Android Jr Member mth04's Avatar
    there is a ROm dump somewhere. i will look around for it. They ported 2.1 to the Droid using it. Look over at our sister site. Droidforums.net I think in the hacks section you may find a way to get the OS fixed
    Here is a link to the thread
    Junior Member Vulcan1600Rider's Avatar
    Quote Originally Posted by Miami1683 View Post
    You rock over here to Miami! I hope the O.P. gets his phone fixed so he doesn't have any 'splainin' to his friend.
    Quote Originally Posted by Vulcan1600Rider View Post
    Thanks we try to keep our members happy. I also am wondering what happend to the OP and the device
    Junior Member vzwmandroid's Avatar
    I'm calling BS on the op
