Audio stops streaming on Wifi
This is a discussion on Audio stops streaming on Wifi within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I used to do the following on the G1.. just about every night for the last year: I open StreamFurious. I select my audio stream ...
Results 1 to 10 of 10
Thread: Audio stops streaming on Wifi
    Member pwoz's Avatar
    1. I open StreamFurious.
    2. I select my audio stream (I love metal!)
    3. I set the timer on 45 minutes.
    4. I rest my G1 against the alarm clock so the speaker is angled towards me.
    5. zzzzzzzzzz + music
    Last night, every time I leaned the phone against the clock or just held in hand, the stream would stop after 10-15 seconds... then I switched to 3g and it worked.
    This is not a big deal, but I prefer using wifi at night since I use 3g streaming A LOT during the day when I'm away from my home network. Any idea what would cause wifi to disconnect?
    I am still experiencing this issue and am hoping someone could test.
    Using wifi, stream some audio from A Radio Online, DroidLive, StreamFurious, etc and then hit power to hide the screen (or wait to timeout) and let me know if you have any interruptions. Please?
    Another bump... still experiencing this issue.
    Weird... I wonder what is causing mine to stop.
    I stream many times daily, from 3G/Edge and wifi, with screen sleeping, and no issues. Indeed, I sleep streaming overnight (earbuds), screen asleep over wifi every night, still streaming when I wake 6-10 hours later. This is with the phone plugged into AC power.
    Maybe it's my settings. Do you use anything specific? I have my wifi ON when it's plugged into usb or the wall. It happens with ALL my streaming apps. grrr
    Member phunds's Avatar
    I used to get this issue too, but with my laptop connecting to my home wifi. I messed around with my router settings and it fixed it. All i did was change the channel that my wifi transmits on.
    -Phunds
    :nexusx: Nexus One owner since: January 11th, 2010
    :nexusx: Rooted! Android 2.2 FROYO CM6.1 RC
    phundsblog.blogspot.com | twitter.com/phunds | facebook.com/phunds
    Quote Originally Posted by phunds View Post
    Tried all channels, but still happens. Apparently this is a known issue (saw something on google's dev site).
    UGH
    Quote Originally Posted by pwoz View Post
    UGH
    Where? Wonder why it isn't happening to me! :P
    Issue 1698 - android - Wi-fi loses connection with router frequency and doesn't reestablish automatically - Project Hosting on Google Code
    I never had this problem with my G1, but after spending $530 on a new phone, I'm quite pissed that I can't maintain a friggin wifi connection.
    I've tried EVERY app on the market that claims to prevent your wifi from sleeping, but nothing works. It makes absolutely no sense.
    Router/modem is from Verizon, but works 100% for my G1. The N1 is going to sleep mode when I tell it not to (Never in the options), but it still sleeps on wifi. I hope today's OTA update addresses this issue, as it fixes the 3G one.
    A router firmware update did the trick. I have an Actiontec modem/router that I got from Verizon for FIOS and for a while there was no firmware upgrade.. until this weekend. woohoo!
android audio stream stops after 30 mins
android audio streaming timeout issue
android device stops radio streaming after 10 sec
android stops streaming
android streaming app stops screen timeout
android streaming stops after 30 seconds
audio stops when streaming on laptop
audio streaming wifi problems
my android tablet stops streaming radio
my radio streams stops on my android device
nexus 7 sound works for 10 mins then stops
s4 stops streaming music wi-fi
stop streaming on your android
streaming stops in my tablet
toshiba tablet audio stops
