Audio not working in vehicle bluetooth
This is a discussion on Audio not working in vehicle bluetooth within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I have a 2009 dodge ram with uconnect (mygig) bluetooth phone system. My nexus one pairs just fine, and can dial from phonebook and monitors ...
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: Audio not working in vehicle bluetooth
    Junior Member josh_909's Avatar
    I have a 2009 dodge ram with uconnect (mygig) bluetooth phone system. My nexus one pairs just fine, and can dial from phonebook and monitors incoming and outgoing calls.
    My problem is there is no audio from the stereo system. I have tried hitting the "bluetooth button" on the phone while in the call, still nothing. It's quite annoying that it *almost* works.
    I had a problem with my windows mobile 6.1 phone, the Tilt (HTC TYTN II) but it wouldn't pair at all. I did a software update on my UConnect system (had to download and burn myself) in the truck, and it started working after that. I am on the latest update possible for my uconnect/nav system.
    WHAT'S UP GOOGLE?? u already jacked up my engraving because I used some unicode characters. =(
    I still <3 my nexus one though....
    Junior Member auditd0rk's Avatar
    Same thing with my '10 Mazda 3. Phone works fine, but no audio when paying music.
    Junior Member esco's Avatar
    Hooked it up on my 09 3 series, pairs fine but for some reason the contacts confuse it i think... so the phone is put in a perpetual "loading" mode on the car and functions don't work. only fiddled around for like 5 minutes or so, will try again later... but I'm having the same problem, no audio and the "almost working" syndrome
    Junior Member jack2k5's Avatar
    my BMW 535i is does not work on the music either. Only phone call and contacts.
    I also tried to hook up with my USB port in the car. It can mount allright. But it wouldn't read the files.
    If someone has a solution to the issues above, please advise. Thank you.
    Super Moderator ggrant3876's Avatar
    Oct 2011
    Have a ford sync and it won't pair, there was an error during pairing. Very frustrating. Tried several times, almost get the code in then I get an error before it pairs. Never had a problem with the G1 or Behold II.
    I paired on my 07 G35 successfully. I couldn't make outgoing calls for some reason. The car recognizes the phone making an outbound call so it switches to the phone channel but quickly kicks out of it and goes back to radio/CD.
    It works fine, however, on incoming calls.
    Weird.
    NXS
    NXS is offline
    Member NXS's Avatar
    I'm sure with all of these posts someone has tried it, but I notice when I pair my headset (which is calls only, not mean for music) that it says under the settings that it's been setup for calls --- any chance that after you pair it with a device that supports stereo like your car or headphones that there's an option under the device settings that permits music output?
    Happy Nexus One User Since Jan 6, 2010.
    On Amazon: Nexus One Chargers, Sync Cables, Headphones, and Cases.
    Junior Member stramt's Avatar
    I'm having the same problem with my 2010 Jeep Grand Cherokee. The phonebook syncs and the display shows i'm in the call, but audio goes to the handset. Incoming calls seem to work fine.
  1. When will the Behold get Android 2.2?
  2. Voice navigation
    Last Post: 10-26-2010, 08:15 AM
  3. Samsung working on gps fix
  4. Sense UI vs MotoBlur vs Samsung UI
    Last Post: 08-07-2010, 05:13 PM
bluetooth phone paired but no sound from car speakers
car bluetooth phone works but audio doesn't
hct sensation paired with uconect no sound
htc has no sound with uconnect
htc one pairing bluetooth audio not working
mazda 3 sync bluetooth
mercedes bluetooth no sound mic
my htc sensation will not work with uconnect
nexus 5 bluetooth audio not playing through speakers sync
no sound from uconnect
speakers not working with uconnect
uconnect bluetooth not working
uconnect no audio
uconnect no sound
uconnect not working no sound
