hard reset?
This is a discussion on hard reset? within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; hello i have been reading online but have yet to figure out a way to do a hard reset/factory reset on this phone, can someone ...
Results 1 to 9 of 9
Thread: hard reset?
    Junior Member ervin10's Avatar
    hard reset?
    hello i have been reading online but have yet to figure out a way to do a hard reset/factory reset on this phone, can someone help me out?
    Thank you
    Junior Member Allhailpoptart's Avatar
    There is a factory data reset built into the phone from Google. It will wipe out all user data and restore the factory settings. I assume this is what you are looking for, it can be found by:
    -Pressing the hard menu button
    -Select "Settings"
    -Select "Privacy" from the menu
    -Select "Factory data reset"
    But make sure you really, really want to do that before you commit to it. Although with Google/Facebook account synching it wouldn't be hard to get your contacts back.
    Hope that helps.
    Thank you very much im new to android, im coming from a iphone so its a bit different, but im learning. Thank s again
    Anytime. Android is great once you get used to it you'll be up and running at least as well as you were on the iPhone, if not better.
    I'm not sure if that factory reset has permission to wipe the SD card as well. I would suggest backing up any pictures/videos you want to keep before you reset the device just in case.
    In the contacts screen, if you hit the Menu button there is a option to Export Contacts to SD card. It saves all of the names and contact pics onto the card!
    I had to do a factory reset to remove the gmail address I put on it. It deletes ALL of your PAID apps, so either uninstall the paid apps if its under 24 hours for the refund, or you can redownload it after for free. It doesn't delete what you have on your SD card, or SIM card. It also doesnt affect anything that is backed up into Google account.
    @NEONmonstar
    Rooted NexusOne
    Cyanogen CM6 RC1 FROYO
    RA-nexus-v1.7.1-Cyan
    Galaxy S PRO Theme
    Desire Camera
    ok cool, and thank yall for the help. Im really liking this phone i dont have to jailbreak it to do the stuff i couldnt do with the iphone.
    Good to know about the contacts export. Thanks for that heads up.
    Member zukbang's Avatar
    another way to do it is power off-hold volume down + power button.
    Junior Member shawnee_nexusone's Avatar
    Quote Originally Posted by zukbang View Post
    true, and this will do a clean wipe--- just like it is outta the box, the reset in privacy as described above is not the same
android box will not power on after hard reset
can not hard reset galaxy s cyanogen help
hard reset
hard reset htc nexus one
how to reset nexus 1
power volume down for cyanogen reset
reset htc nexus one
