Issues with USB/Mounting SD Card
This is a discussion on Issues with USB/Mounting SD Card within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I am having the same problem. Just got a new SDHC card with 16Gb class 6 and first off all it won't stay mounted as ...
Results 11 to 17 of 17
Thread: Issues with USB/Mounting SD Card
    Junior Member Ricmel01's Avatar
    I am having the same problem. Just got a new SDHC card with 16Gb class 6 and first off all it won't stay mounted as the phone suggests and then the computer can't find it. Instead I get a message " Please insert a disk..."
    Junior Member brog_alien's Avatar
    Looks like this thread has gone dead but would appreciate a solution...
    I have a win7 32bit laptop and am connecting n1 to it. I see the removable drive but cannot access the SD card. clicking on the drive reports "Insert a disk in drive E:".
    I tried updating the disk drivers, and sometimes I will be able to access the SD card for a second or so and then would loose it...
    Any suggestions?
    Borg
    Junior Member kepster's Avatar
    Im having the same problem as well. Im using WIN7 32 bit. Cant get my SD card to stay mounted
    i just got a new card and it was working fine then one time when i connected and the menu popped up instead of open folder i clicked on use this for back up or something so i hit cancel real quick and then my comp would not recognize my card for some reason. i unchecked the USB debugging option and then tried again and it worked. i dunno it could work for u guys too.
    Junior Member richpb7's Avatar
    This turned out to be a combination of problems for me. Final solution after making sure the correct drivers were installed, etc., was to choose a different USB port. Go figure :-)
    Junior Member zulfikhar's Avatar
    Hi all,
    I was also having this problem, where my phone will be connected for some time then get disconnected and was not able to transfer any data...
    Then i noticed i was not using my Original USB cable which came with the phone, when i connected the original cable it started working fine.,...
    TIll date i dont having any problems...
    It might be the same issue for you, try changing the USB cable and use it...
    Android Lurker Qfdv's Avatar
    May 2014
    Usb storage set up
    I got an "android tv" with Android v. 4.2.2. SD storage works, but usb storage does not. In settings/Storage/USB Storage the "mount this storage" is grey out. How can I set it?
    Thanks
    Daniel
  1. SD Card Issues
    By jhcii in forum LG Ally Help
    Last Post: 02-19-2011, 08:10 AM
  2. Text and SD card issues
    By mauhl1 in forum LG Ally Help
    Last Post: 01-22-2011, 11:06 PM
  3. SIM Card & txt Message Issues
    By bjblackmore in forum Nexus One Tech Issues / Bug Reports
    Last Post: 09-07-2010, 09:56 AM
  4. SD card issues
    By droidhead in forum HTC EVO 4G Tech Support
    Last Post: 06-16-2010, 11:06 AM
  5. issues with SD card
    By knightrider in forum Nexus One
    Last Post: 06-02-2010, 04:35 PM
android 4.2.2 mount usb drive
android insert an sd card for mounting
android phones as usb drive ouya
android usb mounting 4.2
asus tablet sd card will not stay mounted
fail to mount/unmount device storage card. (1020)
failed to mount sd card xoom
failed to push to sd card ouya
inseert an sd card for mounting
insert usb for mounting in android razor m
mount hdd on ouya
nexus 1020 not able to mount the usb storage
ouya sd card 32 bi
ouya usb disk 16gb
ouya usb storage not munting
