Issues with USB/Mounting SD Card
This is a discussion on Issues with USB/Mounting SD Card within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; First of all, I thing my N1 is GREAT, except for one issue. When I select the option to mount the SD card, card, momentarily ...
Results 1 to 10 of 17
Thread: Issues with USB/Mounting SD Card
    Junior Member jbartee's Avatar
    Unhappy Issues with USB/Mounting SD Card
    First of all, I thing my N1 is GREAT, except for one issue. When I select the option to mount the SD card, card, momentarily my computer recognizes it, but then I select the drive representing my N1 and my computer indicates nothing is attached.....
    I actually took the mini SD card out of the phone and put it in the computer directly, which was recognized, so I know the card is fine.
    I have Win Vista - 64 bit.
    Does anyone else have this problem? is there someone at Google I can call?
    Thanks for any info
    Follow up to my post...Phone drivers do not work for 64 bit computers
    I called HTC and they suspected it that the 64 bit OS was not suported by the drivers. I confirmed this becasue I could mount the SD card to my 32 bit XP machine.
    Quote Originally Posted by jbartee View Post
    I can confirm it mounts fine on my 64bit Windows 7 rig.
    Junior Member Allhailpoptart's Avatar
    You are correct in thinking this is an issue with the 64bit architecture of Windows. xda-developers.com had a thread regarding this a while ago for other android devices (this is NOT a Nexus One only problem, but I can't seem to dig up the post).
    You will need to install a new driver in order for the computer to properly see the device when connected. Follow this link, the driver you need is wrapped into the SDK Android SDK | Android Developers
    I haven't played around with that particular install yet but it came up on a few other forums which makes it believable that it will work.
    Let me know if that helps.
    Junior Member MrMarkAZ's Avatar
    I'm having this problem in Windows XP Pro 32-bit edition
    I attached the Nx1 via USB. Windows recognized the USB device as a Nexus One hard drive or some such. A new drive appears in Windows Explorer, but when I click on the drive letter, I get the error message that I need to insert a disk. Settings in the Nx1 phone show that there is a 4GB storage card inserted with 3.xx GB free.
    I haven't tried inserting the card directly into the computer via a USB adapter ... I thought I could just attach the phone directly and I could a) charge the phone if needed and b) transfer files to and fro.
    Any ideas? Do I need to format the card first before Windows will see it?
    Junior Member ruckus10's Avatar
    Quote Originally Posted by soulstar View Post
    me too..no problems at all with my 64 win 7
    Quote Originally Posted by MrMarkAZ View Post
    Once you connect the phone to the computer there is a notification that pops up in the top bar. Open your notifications and click the USB option, it will then prompt you to mount/unmount the phone as a storage device. That should get you what you're looking for.
    That got it
    Quote Originally Posted by Allhailpoptart View Post
    To quoth Krusty the Klown: "Ahhh, CRAP!" I didn't know that there would be a notification on Nexus. Once I tapped that, the drive was accessible from within windows.
    Thanks, and yes, all must hail the pop tart. 'Tis a redoubtable culinary invention.
    wmm
    wmm is offline
    Member wmm's Avatar
    Normally that works for me. However, a couple of times I have pushed the "mount" button in the notification on the Nexus One and nothing happened -- it never published the SD card to the host computer. Nothing I was able to do, short of power-cycling the phone, would allow the host computer to mount the card. I don't have any idea what might be different about the couple of times that it failed; most times it works exactly as designed.
    Member gr8gorilla's Avatar
    win 7 64 and sd card problems
    I cannot get the SD card to stay mounted. I mount it and it instantly dismounts it will not stay mounted at all. It works fine on 32 bit os. I have the lasted SDK developers drivers installed. Any help is appreciated.
    :nexusx:Proud new owner of Nexus One as of 1/11/10
    Unlocked Rooted
    Amon-RA recovery v1.7.0(Cyanogen Mod Version)
    Cyanogen Mod LATEST! (Beta or Stable)
    Baked In MoDaCo's Kitchen!
    NexTHEME
    Helix Launcher2
    16GB Class 6 MicroSD
    Twitter @Gr8gorilla
  1. SD Card Issues
    By jhcii in forum LG Ally Help
    Last Post: 02-19-2011, 08:10 AM
  2. Text and SD card issues
    By mauhl1 in forum LG Ally Help
    Last Post: 01-22-2011, 11:06 PM
  3. SIM Card & txt Message Issues
    By bjblackmore in forum Nexus One Tech Issues / Bug Reports
    Last Post: 09-07-2010, 09:56 AM
  4. SD card issues
    By droidhead in forum HTC EVO 4G Tech Support
    Last Post: 06-16-2010, 11:06 AM
  5. issues with SD card
    By knightrider in forum Nexus One
    Last Post: 06-02-2010, 04:35 PM
android 4.2.2 mount usb drive
android insert an sd card for mounting
android phones as usb drive ouya
android usb mounting 4.2
asus tablet sd card will not stay mounted
fail to mount/unmount device storage card. (1020)
failed to mount sd card xoom
failed to push to sd card ouya
inseert an sd card for mounting
insert usb for mounting in android razor m
mount hdd on ouya
nexus 1020 not able to mount the usb storage
ouya sd card 32 bi
ouya usb disk 16gb
ouya usb storage not munting
