No e-mail notification sound?
This is a discussion on No e-mail notification sound? within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Whenever I get an email, I don't hear any notification sound, so I went in and tried to edit the notification sounds in my settings..and ...
Results 1 to 8 of 8
Thread: No e-mail notification sound?
    Junior Member GeneticFusion's Avatar
    Whenever I get an email, I don't hear any notification sound, so I went in and tried to edit the notification sounds in my settings..and whenever i tap to preview a tone, it doesnt play! My sound is on and my volume is up all the way, anyone else having problems with this?
    4 times
    Any problems with sound from other apps?
    Well, just woke up and the keyboard clicks are very very low, as well as whenever i select an icon, it makes a sound, just so low you cant hear it unless you put it up to your ear.
    Junior Member Will_nexusone's Avatar
    im having the same problem. i want it to vibrate and play my notification sound when i get a new text message but it wont do either of them. ive tried everything i can think of-even a factory reset but it STILL does it.
    ideas?
    Junior Member cocoaju's Avatar
    It seems like you have a faulty device. If you can't set it to ring or vibrate, send it back and get it exchanged. I would...
    its not that i cant make it do that...its just that sometimes it wont stay that way. i can set it on vibrate and it works fine for a while but then sometimes itll randomly stop vibrating at all and assume that i can see the glowing trackball from inside my pocket.
    That seems like a SW issue. Hasn't happened to me yet. If it does, I will post it. Just in case, I think you should contact HTC to see if you need to take it back. You have 14 days to change it or it will go on warranty instead.
    i think i *might* have figured it out. it seems like if you leave the message screen open and then turn the screen off when a new SMS comes in the phone treats it as if you had it on and were looking at the screen, but when you go back to the home screen and turn the phone off when a new SMS comes in it will vibrate normally.
    can anyone confirm this?
android chime but no mail
android no email alert when screen off
android no email notification
android no email sound
android no sound notifications email
android phone no mail notification sound
cant hear notification sounds on android cat phone
nexus 2 turn off email notifications, leave ring vibrations
nexus 6 notification sound low
no e-mail notification or sound in nexus galaxy
no sound e-mail android
no sound on email notification on nexus phone
no sound or notification icon when aol email comes in in android
no sound when email comes in to android
notification sound nexus 7
