T-Mobile visual voicemail issues
This is a discussion on T-Mobile visual voicemail issues within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hi everyone, have had my N1 for 2 days now (on T-mobile), and noticed two issues with the visual voicemail app (after having to call ...
Thread: T-Mobile visual voicemail issues
    Junior Member polbit's Avatar
    Hi everyone, have had my N1 for 2 days now (on T-mobile), and noticed two issues with the visual voicemail app (after having to call 611 and getting the feature activated - that part went smoothly):
    1. When out and about, if I receive a voicemail, it works - VM icon shows up, then VVM icon, then VM dissapears. Wierd, but works. I can then go throught the app and listen to the voicemail, etc. However, if I switch back to home screen, then try to go back to the voicemail app, it shows a non-responsive inbox screen, and I get a message about Force Close. Then if I restart it, it works great...
    2. It does not seem to work when I'm on WiFi. Is that the case, or is there a setting somewhere that I can change? I'm on WiFi at home, and any new voicemail is not noticed at all by the Visual Voicemail app....
    Any suggestions would be appreciated,
    Polbit
    Junior Member genuity's Avatar
    Quote Originally Posted by polbit View Post
    I believe there is a disclaimer on the app description itself that it will not work over wifi:
    T-Mobile Visual Voicemail
    T-Mobile USA
    Voicemail just got better! With Visual Voicemail you can now listen to messages in any order, respond in one click and easily manage your inbox without ever dialing into voicemail.
    Release Notes: 1.0.12
    -Stability and performance enhancements
    -Does not work over Wi-Fi
    Version 1.0.12 461KB
    Ah, thanks for that, I guess I should read those more carefully...Now if I can only stop making it crash...
    Polbit
android 4.0.4 problem with visual voicemail on t mobile
android visual voicemail force close
android vvmcounter
section 7 vvm voicemail counter
t mobile visual voicemail problems
t mobile voicemail problems
t-mobile visual voicemail force close
t-mobile visual voicemail problems
t-mobile voicemail issue
tmobile visual voicemail app issue on android
tmobile vvm over wifi
windows phone voicemail issues t mobile
