microSD Storage Problems
This is a discussion on microSD Storage Problems within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I powered off my phone and removed the microSD card to load some photos onto it that would be good backgrounds, etc.. When I put ...
Thread: microSD Storage Problems
    Member bmo's Avatar
    I powered off my phone and removed the microSD card to load some photos onto it that would be good backgrounds, etc.. When I put the card back in and powered on the phone, the gallery will not find any of the new pictures I added. Also, the folder in the gallery containing pics I had taken with the phone's camera is no longer there.
    Anyone else tried this or has anyone experienced problems like this?
    Any ideas if I did something wrong (I put the pics in the root of the microSD as I didnt see a folder caled "photos" or something like that)?
    thanks
    4 times
    Have you tried to connect the Nexus to the PC and Mount the sdcard that way?
    Member bmo's Avatar
    haha now that would have been the smart thing to do now wouldn't it.
    4 times
    Quote Originally Posted by bmo View Post
    It's easy to overlook things....
    I have my folders set up as
    Media
    >>photos
    >>wallpaper
    >>ringtones
    >>notifications
    Member bmo's Avatar
    so for everyone out there, you may lose the hotos youve taken if you remove the SD card without unmounting it (even if the phone is powered off) and plug it straight into your computer. Use the included USB cable that I forgot i had, then its all good. :/
  1. T-Mobile announces Dell Streak 7, it's first 4G Tablet
    By JohnDroid in forum Android News
    Last Post: 01-06-2011, 02:22 PM
  2. 1.9 ghz kernal for the g2
    Last Post: 11-15-2010, 07:22 PM
  3. What are your plans for the Galaxy Tab
    Last Post: 10-05-2010, 09:19 PM
