Very Bizarre problem.
This is a discussion on Very Bizarre problem. within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; So I can't consistently reproduce it, but I've managed to have it happen 3 or 4 times now. Basically when I'm on a call and ...
Results 1 to 10 of 20
Thread: Very Bizarre problem.
    Member Keiran's Avatar
    Basically when I'm on a call and I go to hang up, for whatever reason the task bar from the top is partially dragged down, and I can't actually interact with the screen at all. Cannot press the "End" button to hang up, can't push the task shade up or down.
    The only way I've found to get out of it is to go to the home screen, and then back to the phone app.
    Obviously this is less than desired - anyone having this problem? Have a solution?
    Might be worth mentioning that both times I've done this "Advanced Task killer" and it's been present in the task bar.
    jah
    jah is offline
    Senior Member jah's Avatar
    I've had this happen numerous times in the last few days. It's extremely annoying and definitely the biggest bug I've seen, of several. Once I had to do a hard reboot to get it to hang up the phone.
    I got a error similar to this.
    I'll be in a call or browser, and the android drop menu will slide down, and then pop up. When touching anywhere on the screen, the menu will slide down again as if it is being dragged, and its impossible to unselect the drop down unless you exit to home.
    @NEONmonstar
    Rooted NexusOne
    Cyanogen CM6 RC1 FROYO
    RA-nexus-v1.7.1-Cyan
    Galaxy S PRO Theme
    Desire Camera
    I have not got the phone yet, but hopefully most these bugs can be fixed with software updates, and its nothing permanent
    It happened on every single call I had today. This is really not acceptable.
    Bizarre indeed. Are you all saying the notification bar drops down all on it's own? Was there anything showing in the no-bar (like an originating call)? Or is the no-bar clear?
    That's exactly what happens. It's happened with something there, and with nothing there.
    Member jbarrack's Avatar
    This happened to me today too --- Its is ridiculous. Seems to be lots of bugs with this device.
    Are you all running Advanced Task Killer? (Those of you having the problem anyhow)
    Junior Member jgunit's Avatar
    I have a G1 not a nexus, just looking at the forums to see if its worth it to buy one now or not.
    I have this problem on my G1 sometimes ( I use advanced task killer) the problem is a simpler fix for me than most report, all i do is slide the task bar back up. It does the same thing for me where no buttons work, but i think it has to do with your ear just sliding the taskbar partially down during calls.
    Junior Member binarysolo's Avatar
    I came on here hoping I wasn't the only person with this problem. Glad I'm not alone!
drop menu
