Auto brightness glitch
This is a discussion on Auto brightness glitch within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; It doesn't happen continuously, but it does occur frequently enough for me to notice: without provocation or warning, my display will get much brighter, then ...
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Auto brightness glitch
    Member wmm's Avatar
    It doesn't happen continuously, but it does occur frequently enough for me to notice: without provocation or warning, my display will get much brighter, then about five seconds later (which I think is the sampling interval for the ambient light sensor) it goes back to being dim again. Has anyone else seen this? I'm thinking I may have a minor hardware defect in the ambient light sensor. It does respond appropriately when I've tested it by shining a bright light on it or covering the sensor with my finger.
    4 times
    Just to let you know that My droid does the same...And the tech at VZW says it's normal....I have learned to ignore it for the most part.
    jah
    jah is offline
    Senior Member jah's Avatar
    I've been trying to ignore it, too. I find it interesting that it's a "normal" feature.
    Member wmm's Avatar
    Yes, I agree -- "known problem," perhaps, and maybe even "not important enough to address," but not "normal behavior."
    I don't consider that a defect or glitch. When I will be walking through my house, the light will do that. I think its just doing what its supposed to. If the battery is the issue, I would turn it down to low.
    @NEONmonstar
    Rooted NexusOne
    Cyanogen CM6 RC1 FROYO
    RA-nexus-v1.7.1-Cyan
    Galaxy S PRO Theme
    Desire Camera
    Member wmm's Avatar
    My problem is that it happens without any change of light -- when I am sitting in one place holding the phone still, just reading a web page or whatever. That's what I consider a defect.
    Member joker's Avatar
    it's possible you're blocking the sensor with one of your other fingers
    which triggers the sensor
    ... I'm minimalist and turned off auto brightness
    I simply use the "3" settings from the home page - off / medium / high
    Member wmm's Avatar
    Yes, I thought about that, but it happens when my fingers are nowhere near the ambient light sensor. Also, what happens is that the screen gets suddenly brighter, much brighter than appropriate for the ambient lighting, then dims back down; if I were covering the sensor with my finger, that would simulate a dark room and the screen would get dimmer, not brighter. (At least I don't think my fingers are bioluminescent! )
    Well this happens on my BB 9700 if i put my hand around the sensor.
    Metro Atlanta
    54 times
    Quote Originally Posted by wmm View Post
    Have you called HTC support about this yet?
auto brightness nexus 4
light sensor nexus 4
nexus one light sensor location
tablet gets dimmer then brighter auto brightness is off
