Small Hole
This is a discussion on Small Hole within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Does everyone have that small hole in the top of there new N1 ? Or am I missing a rubber plug ?...
Results 1 to 8 of 8
Thread: Small Hole
    Android Lurker Michael A's Avatar
    Small Hole
    Quote Originally Posted by Michael View Post
    Can you be more specific? I don't see any holes though
    Junior Member sixty4's Avatar
    the headphones jack?
    Metro Atlanta
    53 times
    If you mean the really small hole on the upper side of the back of the phone, that's the second microphone for noise canceling feature.
    Its a small hole to the right of the power button and how do I get my contacts off my simm?
    ok It is for the headphones but I thought there would be some kind of rubber plug in there for when your not using the headphones, I could see right down inside the phone
    Metro Atlanta
    53 times
    That's not at all unusual! You may be able to find some sort of rubber plug for the headphone jack if you hunt around, if you think you really need one.
    does the hole for the headphone jack suppose to have a plug in it, mine is just an open hole
galaxy s3 hole on top
galaxy s3 small holes
nexus 4 hole in the top
nexus 5 hole on top
small hole in top of galaxy s3
small hole on top of galaxy s3
what are the little holes i'm my s3 for
what are the small holes at the top of my galaxy nexus phone
what are various holes for nexus 4 phone
what is the hole on top of the nexus 7
what is the small hole on top of galaxy s3
