WiFi Issue
This is a discussion on WiFi Issue within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I don't broadcast my WiFi SSID... When I configure the Nexus One to use my WiFi, it always says "remembered, not in range"... If I ...
Results 1 to 9 of 9
Thread: WiFi Issue
    Member gmccauley's Avatar
    WiFi Issue
    I don't broadcast my WiFi SSID... When I configure the Nexus One to use my WiFi, it always says "remembered, not in range"... If I broadcast my SSID, then it connects.. Anyone else having this issue?
    Junior Member shawnee_nexusone's Avatar
    Quote Originally Posted by gmccauley View Post
    what type of router is it? and what protocol, is it N?
    Issue is resolved, I found help through a senior tech at HTC
    4 times
    Quote Originally Posted by shawnee View Post
    What was the Fix
    we went from a WPA-PSK to a WEP setting on a NetGear N protocol router
    4 times
    Thanks.......
    I live in FL and I stay in MD during the week for work.. I had the problem in both locations.. I haven't tried broadcasting my SSID in FL yet as I didn't think about it until it didn't work in MD either..
    In MD, I have an ActionTec MI424-WR using b/g..
    In FL, I have an ActionTec GT704-WG using b/g and a couple linksys access points using b/g/n..
    Is your router configured to broadcast your SSID?
    no it is named and secured
droid dna netgear issues
gt704-wg android wifi
nexus 7 not receiving wifi ssid
premier gt704
premier tablet android gt704
