Contacts won't show on phone!
This is a discussion on Contacts won't show on phone! within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; So, I manually added all contacts in my phone. At some point, they synced to Google, and i noticed that when texting, multiples of the ...
Results 1 to 10 of 12
Thread: Contacts won't show on phone!
    At some point, they synced to Google, and i noticed that when texting, multiples of the numbers would show up.
    I checked my contacts, and inside each contact, there would be DOUBLE contacts. I went online to Google Gmail, checked my contacts, and there indeed was TWO of each contact.
    So i went through my contact list, deleted each one manually. Then I went to call one of my friends, and I noticed her name wasn't on my contacts, but it WAS on my Favorited Starred list. Confused, i deleted the contact, and re-added the contact, and it STILL WOULDN'T show on my contacts.
    I searched the name in the contacts and the name showed up in the search, but wouldn't show up on the main contacts list! I went onto Google contacts, and the number indeed was online but I had to click MOVE TO MY CONTACTS for them to show up on my phone?
    My main question is, how can you add contacts directly onto the phone? I'm almost positive it worked just perfectly before..... I know it can't be that difficult to add a contact!
    @NEONmonstar
    Rooted NexusOne
    Cyanogen CM6 RC1 FROYO
    RA-nexus-v1.7.1-Cyan
    Galaxy S PRO Theme
    Desire Camera
    Junior Member jiveturkeydk's Avatar
    Yes, someone please answer this thread!
    4 times
    Contacts>>Menu>>Display Options....
    Check you settings
    Junior Member pleeming's Avatar
    You're lucky! I manually transferred my contacts from my sim and everything OK for a few days. 4 days later, all gone and I had to do the transfer again!
    Member India Whiskey Charlie's Avatar
    Quote Originally Posted by Backnblack View Post
    Check you settings
    I believe your only choices are all Gmail contacts or only those with phone numbers listed. From day one, I chose "only contacts with phones" and have never had a problem.
    I hope you guys resolve your issues soon as the N1 is a great phone.
    Quote Originally Posted by pleeming View Post
    Your contacts in Gmail are supposed to sync with your phone. Make sure you leave those in Gmail intact. Mine have never gone anywhere.
    4 times
    Also make sure you are sync'ing to Google.....
    Junior Member bfrankois's Avatar
    Question crazy contact list
    I'm having similar issues but I didn't notice until I started manually adding contacts. I would search for that contact in my contact list and it wouldn't be there, then I check my call log and the name and number are recognized. So I don't get why they wouldn't show up on my list, and playing with the settings doesn't seem to make a difference. What gives?
    Android Lurker maris's Avatar
    Quote Originally Posted by bfrankois View Post
    As mentioned above, it has to do with the filtering you have set on the phone. If you make sure all the boxes are checked under the display options and your gmail account, that should make them show up.
    Quote Originally Posted by Maris View Post
    I did mention that I have played with all the settings that I can see, all the boxes are checked and I still have these issues.
  1. Want Gingerbread for Your MyTouch 4G?
    Last Post: 12-29-2010, 12:28 PM
  2. Samsung Epic 4G user's guide
    Last Post: 08-31-2010, 11:14 AM
android phone contacts won't display
android phone won't show some contacts
android why is my phone displaying call numbers not names
android wont display contacts
contacts wont appear on new phone
my android phone dont display contacts
my android wont show my contacts
my phone wont display my contacts
my phone wont show my contacts
phone won't show contacts
phone wont display contacts
some of my gmail contacts wont show after i transferred my number to a new phone
what to do when contacts won't show on phone
why doesnt the contacts display in my phone log samsung
why is it that my android phone dont display my contacts
