How to soft reset?
This is a discussion on How to soft reset? within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Is it merely taking out the battery? Or is there some sort of combo of bottons/actions? Thanks!...
Results 1 to 10 of 10
Thread: How to soft reset?
    Junior Member RealtorRyan's Avatar
    How to soft reset?
    Thanks!
    4 times
    A soft reset is power cycling the device....
    Senior Member M_Woody's Avatar
    Quote Originally Posted by Backnblack View Post
    sorry, i hate to prove you wrong... but...
    "Those of you having issues should do a soft reset of your phone (press power, volume down and the trackball simultaneously)."
    - someone from Google
    M_Woody's wallpaper pack.
    I am a freelance/self-employed graphics designer, please take a look at my website www.m-woody.co.nr
    200th post - 6th April, 2010.
    [SIGPIC][/SIGPIC]
    4 times
    Quote Originally Posted by M_Woody View Post
    "Those of you having issues with the touch screen should do a soft reset of your phone (press power, volume down and the trackball simultaneously)."
    Thanks but the OP said nothing about Touch Screen Issues and someone from google also said a power cycle is a soft reset.....
    Thanks for the answer. I was having screen issues. It froze!
    well, if a soft reset if just power cycling the phone, what does does power, volume down, and trackball do??
    Metro Atlanta
    53 times
    Sprain your fingers? :D
    :rofl3: exactly...
    Talking
    LOL. Yeah, the method that I said is the 'official' way to do it. The easier way too IMO.
    [SIGPIC][/SIGPIC]
    Junior Member Mi|enko's Avatar
    A soft reset is a reset of the OS without any sort of data wipe. This would include both the key combination and power cycling.
    A hard reset would be an OS wipe.
google nexus soft reset
how to do a soft reset on android
how to soft reset nexus 5
how to soft reset nexus one
htc nexus one soft reset
nexus 4 soft reset
nexus s soft reset
nexus soft reset
reset nexus one
soft reset google nexus
soft reset nexus 4
soft reset nexus 5
toshiba thrive soft reset
