Nexus one 3G and Wifi
This is a discussion on Nexus one 3G and Wifi within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hello everyone, Is someone can tell me, sometime, how to switch off the "3G" fonction and to use only "Wifi" fonction. Thanks and Hello from ...
Thread: Nexus one 3G and Wifi
    Junior Member EMarkus's Avatar
    Exclamation Nexus one 3G and Wifi
    Hello everyone, Is someone can tell me, sometime, how to switch off the "3G" fonction and to use only "Wifi" fonction. Thanks and Hello from Switzerland:nexusx::nexusx:
    Senior Member M_Woody's Avatar
    Quote Originally Posted by EMarkus View Post
    look for a program called "apndroid" in the Android Market
    M_Woody's wallpaper pack.
    I am a freelance/self-employed graphics designer, please take a look at my website www.m-woody.co.nr
    200th post - 6th April, 2010.
    [SIGPIC][/SIGPIC]
    Thanks M. Woody, It's seems the app is perfect. Regards Eric
    4 times
    It should be that when connected to wifi, 3G is off.
    But if you drop wifi....3G will pick back up...
    Question Movies installed at origin
    When you got your nexus one you have some Music samples. I did'nt find any movies samples. is that correct ? Thanks
    That's bad news. I need info to switch off 3G when I wish even if Wifi is not available. Problem is that we pay a lot in Switzerland for 3G
    use apndroid, i have it on all the time, i haven't got a data plan
    [SIGPIC][/SIGPIC]
