Silent Calls
This is a discussion on Silent Calls within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I had this happen to me 5 or 6 times a couple weeks ago. Since the update I havent experienced it but that is not ...
Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Silent Calls
  1. #21
    bmo
    bmo is offline
    Member bmo's Avatar
    I had this happen to me 5 or 6 times a couple weeks ago. Since the update I havent experienced it but that is not sufficient to prove the update fixed anything.
    What I have to add is that my friend has a Droid on Verizon and has experienced this same problem. I thought it was a network issue until he told me that he saw the same thing on an entirely different network architecture.
  2. #22
    Junior Member eduardo's Avatar
    microphone doensīt work
    Iīm having these same issues.
    Just got a brand new phone, and the person on the other side of the line canīt hear me.
    Has anybody been able to fix that problem?
  3. #23
    jah
    jah is offline
    Senior Member jah's Avatar
    Mine just stopped doing it. Hasn't done it in several months.
  4. #24
    Quote Originally Posted by jah View Post
    Hi jah.
    Do you remember installing or uninstalling any app before it stopped doing that?
    Or it stopped doing it out of nowhere.
    Right now Iīm using the Nexus only for 3G internet connection, as as a phone itīs useless.
    thanks.
  5. #25
    jah
    jah is offline
    It stopped it out of nowhere, which is super not-helpful.
  6. #26
    Thanks Jah, Iīll hope for the same luck you had.
    So far, itīs been 4 days of silent calls. Very disappointing as it was very expensive and I had vey high expectations of the product.
    Besides that I have to put up with my iphone friends making jokes out of it.
  7. #27
    jah
    jah is offline
    Ok, so after this discussion, I've noticed that the phone still does it from time to time and that I'd just quit noticing. But it's definitely done it twice in the last week.
    That's even less helpful.
android silent call bug
android silent when calling you
call silent android
galaxy s4 att phone calls mic are silent
nexus 4 silent call
nexus 4 silent calls
nexus 6 silent phone call
s4 silent calls
silent calls on galaxy s4 at&t
