MMS Problem
This is a discussion on MMS Problem within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I have a MMS texting problem. I have gone through the settings and they are correct both looking at my iPhone settings, my friends settings ...
Results 31 to 40 of 40
Thread: MMS Problem
  1. #31
    Junior Member iDrian's Avatar
    I have a MMS texting problem. I have gone through the settings and they are correct both looking at my iPhone settings, my friends settings on a Hero and the settings reccomended on my operators website.
    But the thing is, I can recieve a MMS, and I once managed to send a picture to myself. But other than that, it just will not send to anyone.
    I tried to create a new profile with manually entering settings then rebooting, didn't work..
    Anyone have a clue what I can try?
  2. #32
    Quote Originally Posted by iDrian View Post
    Are you using the Norway network? if so have you tried;
    MMSC: http://mms.nwn.no
    Proxy: 09.254.65.20.00
    APN: mms
    Username:
    PW:
    Image Size: medium
  3. #33
    Banned DocMjldds's Avatar
    Are uou using the stock messaging applet, or have you tried the others such as ChompSMS or Handcent. Have you tried sending anm E-Mail using the 10 digit number references to specific networks per my last post. Are you using any modsor is the phone stock.
  4. #34
    I'm confused, it said it couldn't send the MMS, but my buddy told me today that he received my picture.
  5. #35
    So, are you good to go now?
  6. #36
    I am sorta good to go, so far everyone I've tried to send MMS to has gotten it, even though both Handcent and the built-in messagin tells me there was an error while sending. So I won't know when it is an actual error, but this will work for now! :D
  7. #37
    Junior Member fatfei's Avatar
    I have same issue sending long SMS messages. They wont send and just hangs. It doesn't return error symbol just sending icon
  8. #38
    Junior Member reapur's Avatar
    I'm in colorado and I never made any changes during activation and everything seems to be working OK. can send MMS to tmo and vzw, havent' tried ATT.
    But my settings are all the same as what people are saying they should be with the exception of:
    MMS proxy: empty
    MMS port: empty
    yet things work.
    Do I need to be concerned that something is amiss?
    Cheers
  9. #39
    Quote Originally Posted by reapur View Post
    MMS proxy: empty
    MMS port: empty
    yet things work.
    Cheers
    "If it isn't broke, leave as is... "
  10. #40
    Sound advice. Doing just that
android sending mms problem
chompsms vzw apn settings
com.android.mms error sending photo
how to receive multimedia messages on nexus one
is there a problem with sending mms pictures with nexus 4
issue sending mms on nexus one
it takes hours or days to send mms pictures in sms nexus 4
nexus 4 mms not going through taking too long
nexus 4 mms problem
nexus 4 sending group mms problem
nexus one not sending picture messages
nexus tech issues
problem sending mms message using galaxy nexus s on tmobile
problem with android phones sending mms to other android
s4 trouble sending mms
