using Edge when expecting Wifi
This is a discussion on using Edge when expecting Wifi within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I am using my Nexus One with AT&T prepaid. I had the WiFi turned on (and had a WiFi connection) and thought that was what ...
Thread: using Edge when expecting Wifi
    Junior Member DCF's Avatar
    I am using my Nexus One with AT&T prepaid. I had the WiFi turned on (and had a WiFi connection) and thought that was what was in operation, however, after I logged off, I found that my entire session was running with Edge. How do I avoid that?
    I had the same problem. N1 seems to turn off the WiFi during 'sleep', perhaps to conserve power. I use the Quick Settings app to selectively to turn off mobile data. It works.
    Senior Member Rusty's Avatar
    APNdroid, pretty useful widget for this kinda thing.
    Thank you both!
    Last Post: 12-07-2010, 08:42 AM
  2. why wont my phone connect to my computer
    Last Post: 10-14-2010, 09:04 PM
  3. list of accessories for the epic :-)
    Last Post: 08-14-2010, 04:07 AM
