Problems with the screen.
This is a discussion on Problems with the screen. within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I'm having issues with the screen, when it dims and I click on the screen, the sides have random colored lines. And if it dims ...
Thread: Problems with the screen.
    Member milkjuice's Avatar
    I'm having issues with the screen, when it dims and I click on the screen, the sides have random colored lines. And if it dims off, and I bring it back it flashes pinkish red.
    I hope I'm not going crazy, so does anybody else have this problem?
    NexusOne. :nexusx:
    Curious if the led lights may have something to do with this. It doesn't seem to be a software problem, and Ive rebooted numerous times.
    Has anybody else had similar problems like this?
    NexusOne. :nexusx:
    Quote Originally Posted by milkjuice View Post
    It's sounds like a screen connector problem, which means you would have to get it sent in for warranty repairs.
    Junior Member darkfire's Avatar
    Send it in for repair. That definitely sounds like a hardware issue. Sorry to hear about the problems...
    Ugh.. I guess I will have to call HTC monday then. Thanks for the input.
    NexusOne. :nexusx:
    Senior Member Spydaz's Avatar
    Did you do a battery pull? Have you installed any new apps right before the problem started? Do a battery pull and see if that helps.
    MOTO DROID & :nexusx:NEXUS ONE
    Yeah, I've done the battery pull. I havn't downloaded any apps recently, I only have one app at the moment which is, Robo Defense. I also have the problem where you touch an icon on the screen and it self clicks something else. I've searched the web already, and have done everything.
    NexusOne. :nexusx:
  1. T-Mobile announces Dell Streak 7, it's first 4G Tablet
    By JohnDroid in forum Android News
    Last Post: 01-06-2011, 02:22 PM
