What's wrong with the battery
This is a discussion on What's wrong with the battery within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; For the second time this week after I woke up my phone was off. The battery was 60% when I went to bed. I don't ...
Results 1 to 10 of 10
Thread: What's wrong with the battery
    Member Discman's Avatar
    For the second time this week after I woke up my phone was off. The battery was 60% when I went to bed. I don't think this is normal. The wifi is off, the bluetooth if off, the gps is off.
    theres a bug in default messaging app that wont allow the phone to sleep. download and set your default to handcent or chomp and turn off messaging notifications from the old app.
    this should help alot
    I had this happen as well. Woke up to dead battery.
    Quote Originally Posted by supsandroid View Post
    I'm not exactly understanding you on this one.
    Member pwoz's Avatar
    Just plug it in overnight. :P
    Senior Member dg36's Avatar
    It could be a defective battery. The messaging app tells the phone "not" to put the "application" to sleep, so you can continue to receive notifications... anyway, the app wouldn't use that much power.
    Member Germerican's Avatar
    I'm having the same issue. Apparently it's connected to the 3G connectivity issue as described in the t-mobile forum thread below. I do get a decent 3G signal at home and at work and my battery still drains like nothing.
    Re: Cell standby and battery drain - T-Mobile Community
    This phone definitely has some bugs and issues in it. We were all guinea pigs
    FYI,
    One thing I've notice, in the battery use menu > cell standby; Yesterday I was at 49%, I went into details and it showed I had lost reception for 5%.
    Today I'm at 79% and details show 26% lost reception.
    So even though my bars are at full now when I walk around with it i.e stair, basement, elevator etc. this is were the reception will decrease and may even be lost for a moment, which would cause a battery drain as the phone tries to lock onto a tower.
    It would be interesting to see if any of you folks have similar readings with the lost reception and cell standby.
    Junior Member gtrplr71's Avatar
  1. Epic 4G Root Thread
my nexus 7 turns off when battery is at 60%
